About two months ago, out of the blue, my regal didn't start. When I went to turn the key over it didn't engage. There was power everywhere; lights, windows, radio, dash, etc. So, I figured it wasn't the battery. My initial thought was the starter, but there was no traditional starter "clicking." After about five to ten minutes of repeatedly trying the key over and over, it finally fired up. It was fine for about two weeks, then it happened again. Same exact thing. After about 5-10 minutes it started up fine. This has happened about 8 or 10 times in the last two months.
During this time, I also noticed that the "Security" light has been coming on and going off intermittently while driving and I was wondering if it's an electrical/alarm issue?
Also, I have heard that sometimes the key code, on the actual key, wears away. I looked at mine and saw that it was worn and began using my spare. I thought I had cured the problem until it happened again yesterday.
I hate to replace the starter for a few hundred dollars to find out it's a loose wire somewhere.
This probably has nothing to do with it, but the last two times it didn't start I opened the hood, rustled some wires, closed the hood and it started...probably 100% coincidental. I have also tried leaving the key in the on position, shifting to neutral, messing with the locks, etc., but nothing seems to work definitively. Now, I'm thinking that I have no choice but to start with replacing the starter before I'm stranded somewhere.
One additional note, I have had some electrical issues before.
Any thoughts?
Any thoughts?
May 13, 2010 at 2:25 AM
