1999 Buick Regal
DDOTY
  • 1999 BUICK REGAL
  • 6 CYL
  • AWD
  • 156,000 MILES
My anitlock brake light was on mechanic found a loose wire and repair it. If there is a hole in my brake line will the anit lock brake light come on
Thursday, August 13th, 2009 AT 9:11 AM
  • 109,885 POSTS
If you have a hole in a brake line, the brake fluis will drain turning on the lights. Now, keep in mind you will also loose most of the braking ability. Do you see a leak?
Friday, September 4th, 2009 AT 8:26 AM
