1998 Buick Regal wont start
ROBERTMAC
  • 1998 BUICK REGAL
  • 6 CYL
  • FWD
  • 95,000 MILES
Car was running fine. Had a cat get under my hood and when I cranked it it knocked the belt off so I turned it off and it will not crank backup put a new belt on
Sunday, June 21st, 2009 AT 5:10 PM
  • 109,885 POSTS
Chances are it knocked the crank sensor off or damaged the wiring to it. I believe the sensor is on the timing chain cover near the crank pulley. Also, to confirm that this may be the problem, check to see if the engine is getting spark. If it isn't, that is where I would start.
I'll bet the car didn't look too good.
Saturday, June 27th, 2009 AT 7:06 PM
