right side windshield wiper does not work
TLWHISNER
V8 front wheel drive automatic
Right side windshield wiper will not work can be moved by hand. acts like it is not connected.
Jan 14, 2010 at 5:35 AM
  • 110,248 POSTS
What you need to do is remove the cowl at the base of the windshield. Under it is the linkage for the wipers. Check to see if the linkage is disconnected or broken.
Let me know what you find.
Jan 20, 2010 at 9:16 AM
VALDEZ1
six cylinder front wheel drive automatic
hi, my wipers stop working. the screws that hold them in place are still moving and they are still tight, but the wipers only go up half way sometimes and sometimes it moves right off the window. what do you think the problem is?
Dec 23, 2016 at 7:54 AM (Merged)
  • 110,248 POSTS
Remove the wiper blade and check to see if the teeth on the arm and socket are stripped.
