1998 Buick Regal OIL PAN GASKET
138,000 MILES • 6 CYL • FWD • AUTOMATIC
SISTERHOOD40
SOMEONE WANTS TO CHARGE ME 595 TO PUT IN A NEW OIL PAN GASKET. WHAT HAPPENS IF I DON'T GET IT FIXED. I JUST CAN'T AFFORD THIS KIND OF REPAIR
Sep 12, 2009 at 8:48 AM
DONALDGOLDSR
  • 38 POSTS
[quote:68d61adeee="sisterhood40"]Engine Mechanical problem
1998 Buick Regal 6 cyl Front Wheel Drive Automatic 138000 miles
SOMEONE WANTS TO CHARGE ME 595 TO PUT IN A NEW OIL PAN GASKET. WHAT HAPPENS IF I DON'T GET IT FIXED. I JUST CAN'T AFFORD THIS KIND OF REPAIR[/quote:68d61adeee]
Firstly, yes, repair it. You have to check your oil every day until it's repaired. If you go more than a couple days without checking the oil level, you could run out of oil, and cause terminal damage to your engine.
If it's leaking all the time, even when it's hasnt been running for a cpl hrs, you absolutely have to repair it.
Sep 14, 2009 at 12:56 PM
