1998 Buick Regal Ignition Switch
125,000 MILES • 6 CYL • FWD • AUTOMATIC
DEBBYP
  • 5 POSTS
I am having trouble with my car stalling when I put on my turn signals. Also, all of the dash lights go on and my speedometer goes crazy. Before I turn on my car and I put the turn signal on the car will not start. I originally thought it was my turn signal switch which I did replace. My car is still doing the same thing. I order a ignition switch which I told the car parts store what I needed and they order me the wrong part. I think I need the ignition switch that has the large black wire that goes under the dash. What is the difference between the ignition switches and do you think that will solve my problem?
Mar 27, 2008 at 11:05 AM
JUSTLIFE
We had exactly the same problem. We found a burnt contact inside the square ignition switch that has a tumbler inside. Wiped off the carbon and bent it back a little Completey fixed the problem. I recommend that you just by a new ignition switch. Just describe it like I did and the dealer will know.
Jun 6, 2008 at 8:53 AM
