1998 Buick Regal heater blower switch
120,000 MILES • 6 CYL • FWD • AUTOMATIC
PGAN
heater blower switch only works on high
Dec 13, 2008 at 4:34 PM
  • 110,248 POSTS
Hi:
The switch is most likely fine. Try replacing the blower motor resister. It is the most common cause of this problem.
Let me know if this helps.
Dec 28, 2008 at 4:37 AM
GERARDI2000
I replaced the blower motor resistor and the heater still doesn't work consistently but when it does decide to come on it's on high only. If i turn it off it doesn't come back on.
Thanks
Jan 13, 2009 at 5:55 AM
  • 110,248 POSTS
Hi:
What I need you to check is the ground to the motor. Let me know what you find. Please keep in mind, when they only work on high, the resister is the problem 99% of the time. I'm sorry it didn't work. Let me know about the ground.
Jan 13, 2009 at 8:24 AM
