1998 Buick Regal Head Gasket
115,000 MILES • 6 CYL • FWD • AUTOMATIC
TOMWIDLAND
My engine has been overheating a lot lately. I think there is a leak in the water pump, but I also notice burnt oil smell coming from the sparkplug area and leaking oil. Not bad, but leaking. Have I blown a head gasket?
Aug 2, 2008 at 3:30 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:990cdbb0d9="tomwidland"]Engine Mechanical problem
1998 Buick Regal 6 cyl Front Wheel Drive Automatic 115000 miles
My engine has been overheating a lot lately. I think there is a leak in the water pump, but I also notice burnt oil smell coming from the sparkplug area and leaking oil. Not bad, but leaking. Have I blown a head gasket?[/quote:990cdbb0d9]
The over heating is most likely do to the leaking Water Pump. Would have Thermostat Changed also.
The burnt oil at spark plugs and leak most likely is caused by the valve cover gaskets. If was leaking from head gasket the oil wouldn't be around spark plugs.
Check the valve cover gasket for leaks. Clean engine and let run for a while then look to see if you can located oil leak.
Aug 2, 2008 at 5:17 AM
MDENSON
i have a 1998 Buick regal and the serpentine belt keeps breaking what could be causing it to break? i had an tension put on but it is still doing the same thing.
Mar 1, 2012 at 3:50 PM
