with the engien running and foot on brake will not release from park when i push down on the shifter button there is a clicking noise under dash
Feb 13, 2010 at 4:27 AM
KHLOW2008
✓Experienced Mechanic
Hi loyd119,
Thank you for the donation.
There are 2 solenoids under the center console and one of them is not working.
I would suspect the Park Lock solenoid as the brake induces a clicking noise which should be from the BTSI solenoid. However you would need to check if the solenoid is moving sufficiently to release the lock.
