1998 Buick Regal 1998 buick electrical problems
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOCKRAT100
  • 8 POSTS
I have a 1998 Buick Regal that had a bad ignition switch, I thought.
(1998 Buick regal has no power to the fuse block for several circuits. heated mirror, cruise control, hvac and low blower circuits are all dead. Naturally, my cruise control, air conditioning system, and low beam headlights do not work.)
I replaced the ignition switch with one from a boneyard, and now the fuses that are dead are:
power drop
bcm
wiper
crank signal bcm cluster
heated mirror
steering wheel controls
Did I get the wrong ignition switch or is this one bad too? This one came with a white plunger this witha 2 wire connector on it. Not sure what it is for. My car has the shifter on the floor.
Aug 16, 2010 at 12:35 PM
WRENCHTECH
  • 20,758 POSTS
What led you to ignition switch to start with?
Have you checked the fusible links?
Aug 16, 2010 at 12:55 PM
DOCKRAT100
  • 8 POSTS
I had several circuits dead at the fuse block before replacing the ignition switch.
hvac
cruise control
heated mirror
low blower
and low beam headlights don't work.
were all dead. I was told here that since I had no power from the orange wire of the ignition switch that the ignition switch was bad.
Yes, I checked the fusible links, all are good.
Aug 16, 2010 at 1:08 PM
WRENCHTECH
  • 20,758 POSTS
You checked power coming out of the switch but not going in.
Check all the maxi fuses in the engine compartment, especially the 60amp marked BAT#1
Aug 16, 2010 at 1:17 PM
DOCKRAT100
  • 8 POSTS
All the maxi fuses are hot, including the bat1
What is this white and metal thin that the ignition switch arrived plugged into? Why don't I see it on my care somewhere?
Aug 19, 2010 at 9:45 AM
WRENCHTECH
  • 20,758 POSTS
I have no idea what your talking about
Aug 19, 2010 at 10:19 AM
DOCKRAT100
  • 8 POSTS
I bought an ignition switch from a boneyard, and it was shipped to me. When it arrived, I noticed it had a 2 wire connector attached to some sort of plastic and metal part that I cannot find on my car. The part has 2 plungers, so if I push one in, the other pulls in. I thought perhaps they sent me the wrong ignition switch, and that was why I had some systems not working now that worked before.
The 2 wire connector is also on my old ignition switch, but is not used. I can't figure out what this little plunger thing is, or if it is even relevant.
Aug 19, 2010 at 11:05 PM
WRENCHTECH
  • 20,758 POSTS
That's what happens when you deal with junkyard parts.
Aug 19, 2010 at 11:54 PM
DOCKRAT100
  • 8 POSTS
found the right ignition switch, and that fixed most of the problems. Seems the salvage part was bad or wrong.
Aug 21, 2010 at 1:07 PM
