Your brakes are a hydraulic system. If there if a leak in this system from anywhere it will cause air to enter the system. Once air enters the system you will have no pedal. I would suggest having that line repaired properly, and have the brakes bleed of all air.
SPONSORED LINKS
Wednesday, January 20th, 2010 AT 11:56 AM
