1997 Buick Regal trans goes into gear and won't move
1997 BUICK REGAL
200,000 MILES • 6 CYL • FWD • AUTOMATIC
JEFFSF150
I bought a car from a friend with a bad trans I. Thbacked it out of the driveway put it in drive and it hasn't moved since. The fluid doesn't smell burnt,and the fluid level doesn't change when it's running. I was told as I kinda suspected that the pump mite be bad . I havnt taken apart a frt wheel drive trans before only rear wheel drive. And not sure were to locate the pump without haveing to take apart more than I need to my wife really wants her car . Any help would be appreciated thanks
Jan 26, 2010 at 1:53 AM
SCOTTY DEE
  • 592 POSTS
I would replace the transmission with a good used part, or a remanufactured transmission.
Jan 27, 2010 at 2:21 AM
