1997 Buick Regal Speed sensor
YARNFLY
Transmission problem
1997 Buick Regal 6 cyl Front Wheel Drive Automatic
Where is the speed sensor located and how do I replace it? 3800 V6 1997 Regal.
Jun 22, 2009 at 9:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Which speed sensor do you need? Vehicle speed sensor or wheel speed sensor?
Jun 22, 2009 at 9:24 AM
YARNFLY
[quote="bluelightnin6"]Which speed sensor do you need? Vehicle speed sensor or wheel speed sensor?[/quote="yarnfly"] Sorry.Vehicle speed sensor.
Jun 22, 2009 at 8:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle speed sensor is located on the lower right side of the engine compartment, attached to the transaxle. Unscrew it from transaxle and disconnect the connections to replace it.
Jun 23, 2009 at 4:16 AM
YARNFLY
There is a bracket holding it in. Does this need to be removed? If so, how?
Jun 23, 2009 at 8:09 PM
