1997 Buick Regal Oil smell
149,532 MILES • 6 CYL • FWD • AUTOMATIC
MAJOR2654
Lately, I smeel oil inside the car. This morning I found oil all over the garage under the car. I can find where is coming from. Apparently, I need an alligator jack to lift the car and find out. Any ideas?
Mar 22, 2010 at 2:51 AM
  • 110,248 POSTS
If you smell burnt oil, chances are the leak is on the top of the engine. Degrease the engine with a good cleaner and drive it. After about 10 miles check to see if you can see where it is coming from. Chances are it is either a valve cover or intake leak.
Let me know what you find.
JOe
Apr 14, 2010 at 2:51 PM
