1997 Buick Regal no power getting to fuel pump sending unit
JAYMAN420
1997 Buick Regal 6 cyl Front Wheel Drive Automatic 200k miles
I installed a new fuel pump on this car because it was'nt getting any fuel pressure and the fuses/relays all checked out good.I was thinking about running a wire from the ignition switched power source to the pump but I cannot figure out which wire out of the four going into the pump is positive.Can a faulty pass key kill fuel delivery or an aftermarket security system?
Jul 4, 2010 at 8:14 AM
  • 75,988 POSTS
Power the gray wire on the fuel pump connector, the black wire is the ground from the battery positive post and see what happens
Jul 4, 2010 at 8:35 AM
