1997 Buick Regal Chronically Overheating Engine
150,000 MILES • 6 CYL • FWD • AUTOMATIC
SSSADOW
No matter what I do: putting coolant/water in the reservoir, or directly in the radiator, the engine can't stay cool. Within a few minutes of driving my car is always over heating and sometimes I even see smoke coming from under the hood. What could be the problem?
Note: I do sometimes see the coolant leaking out after I've stopped the car, but it doesn't come out right away so I don't understand why it still overheats.
Jun 10, 2010 at 4:09 AM
HMAC300
  • 48,601 POSTS
if you see coolant beneath the car you have a leak. But you may have a stuck thermostat or you could have a bad radiator or inlet or head gasket problem. Best thing to do is to take it to a pro let him pressure check it and other things...
Jun 12, 2010 at 10:55 AM
