1997 Buick Regal brakes stick
133,321 MILES • 6 CYL • FWD • AUTOMATIC
TBARRETT1976
right front brake is sticking, what could be the cause?
Feb 12, 2009 at 10:38 AM
ZACKMAN
  • 4,202 POSTS
Main reason is faulty (usually stuck out) caliper. Raise the vehicle and remove the wheel. Remove lower caliper bolt and try swing the caliper upward. Inspect for damaged piston boot. Try pushing the piston back inside the caliper. If you feel resistance, replace caliper. Make sure you bleed the system once you are done.
Feb 12, 2009 at 2:33 PM
