1996 Buick Regal sparkplugs
GOLDCOOK71
  • 1996 BUICK REGAL
  • 6 CYL
  • 132,000 MILES
If I remove motor supports to get to rear plugs, do I need special tool to move motor back in position
Saturday, April 17th, 2010 AT 2:49 PM
HMAC300
  • 48,601 POSTS
If you decide to do this, then block your back wheels with something so the car won't move, put the car in neutral as it will be alot easier to move the motor and then use a 2X4 to stick between the motor and firewall so it doesn't come back on you while working on the engine. YOu'll need a big bar or something to move the motor forward.
Saturday, April 17th, 2010 AT 6:21 PM
