1996 Buick Regal rear brake calipers
VON737
Brakes problem
1996 Buick Regal Front Wheel Drive 78000 miles
From the looks of the pads I don't believe the brakes have ever been changed on this vehicle. I had no problem compressing the pistons on the front calipers, but I can not compress the pistons on either rear caliper. I even opened the bleeder valves. I find it hard to believe that both pistons could be frozen. Any suggestions. Thanks VT
Sep 17, 2008 at 6:34 AM
DOCFIXIT
  • 18,828 POSTS
Hi von737
You have to rotate the piston clockwise until it bottoms out. Release air from dust boot. They make a tool for this but I have used chanel locks. Grab hold of the cut out area a screw it down.
Good luck
Thanks for donation
Sep 17, 2008 at 7:04 AM
