1996 Buick Regal P0441 Evaporative Emission Control System
1996 BUICK REGAL
94,000 MILES • 6 CYL • 2WD • AUTOMATIC
STL1FANMAN
I just tried to get my emissions inspection.
It failed.
P0441 Evaporative Emission Control System Incorrect Purge Flow
The service engine soon light is on.
What should I do now?
Sep 10, 2009 at 9:36 AM
DTC P0441 could mean one or more of the following has happened:
* Bad vacuum switch
* Broken or damaged EVAP line or canister
* Open in PCM purge command circuit
* Open or short in Voltage feed circuit to Purge Solenoid
* Faulty purge solenoid
* Restriction in EVAP solenoid, line or canister
* Corrosion or resistance in purge connector
* Bad PCM
Here are a few solutions that should be followed to fix this issue.
* Common Chrysler fix - Replace Leak Detection Pump / LDP
* Repair damaged EVAP lines or canister
* Repair open or short in voltage feed circuit to Purge Solenoid
* Repair open in PCM purge command circuit
* Replace purge Solenoid
* Replace vacuum switch
* Repair restriction in Evap line or canister or solenoid
* Repair resistance in purge connector
* Replace PCM
Sep 10, 2009 at 11:10 AM
STL1FANMAN
yeah rasmataz I came across the site that listed that information.
what I am really looking for is the most common solution.
I've been looking around the internet for a few hours and made a couple calls.
the most common solution seems to be replacing the purge solenoid.
I'm probably going to do this. I was just looking for some reassurance.
I read that when this device doesn't open it trips the service engine soon light.
I took it off and tried blowing in the holes where the tubes connect to it. I couldn't blow into it. there is no where for the air to go.
I inspected and blew through all the lines. They seem fine.
If replacing the purge solenoid doesn't work what should I try next?
Sep 10, 2009 at 11:35 AM
DONALDGOLDSR
  • 38 POSTS
[quote:78a38cf5e2="stl1fanman"]Computer problem
1996 Buick Regal 6 cyl Two Wheel Drive Automatic 94000 miles
It failed.
What should I do now?[/quote:78a38cf5e2]
The most common problem when that code comes up is a loose gas cap.
But, if it's a legitmate problem, Id check the vacuum lines in and around the vacuum ball, and the fuel return line.
Sep 14, 2009 at 1:05 PM
