1996 Buick Regal hesitating and sputtering when going up hi
NICKLOW
Engine Performance problem
1996 Buick Regal 6 cyl Front Wheel Drive Automatic high miles
hesitating and sputters when going up hill and also when i accelerate
Apr 10, 2010 at 6:01 PM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 10, 2010 at 10:26 PM
