1996 Buick Regal hard start hot
158,000 MILES • 6 CYL • FWD • AUTOMATIC
MERCYALONE
car starts and runs fine even hot but once it's shut off hot won't restart for 15 minutes
Aug 28, 2009 at 8:46 AM
  • 75,988 POSTS
Next time don't wait 15mins. Do below immediately to catch it.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Aug 28, 2009 at 12:04 PM
