1996 Buick Regal car will not keep running.
GLDNTCH48
Engine Mechanical problem
1996 Buick Regal 6 cyl Front Wheel Drive Automatic
we replaced the fuel pump and the filter but when you start the car it runs for a second then it dies.and if you give it any gas it dies. what do we check for?
May 9, 2009 at 5:34 AM
JERRYGOODWRENCH
  • 77 POSTS
check all injectors for resistance . Unplug each injector and check each one. should reead around 11 ohms. Sounds like one or more is way out of range and shuts down injector pulse as soon as you try to start car..Let me know.
May 9, 2009 at 11:38 PM
