1996 Buick Regal brake lights dont work right
17,800 MILES • 6 CYL • FWD • AUTOMATIC
BIGBUD388
checked every thing good could possiblly be turn signal switch problem how har is it to r&r
May 8, 2008 at 8:01 AM
MERLIN2021
  • 17,250 POSTS
Check on your brake pedal, there you will find the stop light switch, it may need adjusting, or replacement...push it into the bracket, then pull up on the pedal, see if that helps...
May 8, 2008 at 8:13 AM
