checked every thing good could possiblly be turn signal switch problem how har is it to r&r
May 8, 2008 at 8:01 AM
MERLIN2021
✓Experienced Mechanic
Check on your brake pedal, there you will find the stop light switch, it may need adjusting, or replacement...push it into the bracket, then pull up on the pedal, see if that helps...
May 8, 2008 at 8:13 AM
