1996 Buick Regal Blower Motor
50,000 MILES • 6 CYL • FWD • AUTOMATIC
JREED414
The blower motor on the air conditioning when set on high will work for a while then it progressively slows down until it stops. If you turn off the air conditioning and then resestart it after a minute the blower returns to normal and then slows down once again. The blower apprears to work correctly on the next blower setting below the high speed setting.
Jul 6, 2008 at 3:20 AM
  • 75,988 POSTS
Inspect and test the blower motor resistors behind right side of dash in the plenum
Jul 6, 2008 at 6:19 AM
