1996 Buick Regal
1996 BUICK REGAL
PKIRBY29
Engine Performance problem
1996 Buick Regal 6 cyl Front Wheel Drive Automatic
why wont my car idle
Jan 8, 2010 at 4:19 AM
JDL
  • 16,098 POSTS
welcome to the forum, how long since a tune-up? I'd take the throttle-body off and clean it, also, check the iac and tps sensors. Have the trouble codes checked. Some of the national brand autostores used to check codes for free. you might call them and ask.
Jan 8, 2010 at 4:45 AM
PKIRBY29
I just replaced the alternator and battery and now the car wont idle.
Jan 8, 2010 at 6:14 AM
JDL
  • 16,098 POSTS
Were you having the problem before the battery and alternator replacement? Even if the parts are good, if there is a problem with the wiring circuit, somewhere, it will still cause problems.
Jan 8, 2010 at 6:52 AM
PKIRBY29
No problems before they went out. Does the computer on the car need reset?
Jan 8, 2010 at 8:04 AM
JDL
  • 16,098 POSTS
After battery power is lost, the computer may need some time to relearn engine run parameters. In our database, I didn' see a particular relearn procedure for your vehicle. Just by driving the vehicle, it should relearn on its own?
Jan 8, 2010 at 8:32 AM
PKIRBY29
I got the car to idle by letting run for about 10min. Thank you for helping me with my problem.
Jan 8, 2010 at 8:50 AM
