1996 Buick Regal
DEBBI L
  • 1996 BUICK REGAL
Engine Mechanical problem
1996 Buick Regal 85,000 miles
My engine is stalling at red lights and if left to idle
Tuesday, September 14th, 2010 AT 7:46 AM
  • 110,182 POSTS
Have you checked for vacuum leaks? Has the check engine light come on?
Tuesday, September 14th, 2010 AT 1:17 PM
DEBBI L
Thanks for your reply. My check engine light was on when I got the car. A mechanic told me it was because my emissions were too high but not to worry qbout it.
As far as vacum leaks.I wouldn't know an automotive vacuum if it bit me. So.I should have that checked? Forgive me! But I'm totally at your mercy here!
Tuesday, September 14th, 2010 AT 8:05 PM
  • 110,182 POSTS
There are plastic / rubber hoses that carry vacuum from the engine to different compinents. Sometimes the crack or dryrot from heat. As a result, there is a vacuum leak. If you look under the hood, you should see many of them. NOTE: They are not electrical wires. Check to make sure none have come disconnected or damaged. If you are lucky, with the engine running, you may hear a hissing sound where the leak is located.
Let me know what you find. I'm sorry, but this is really hard to explaine such a simple thing. I hope I've helped.
Tuesday, September 14th, 2010 AT 8:35 PM
