1995 Buick Regal wont shift out of first gear
DARENWLUMMUS
Transmission problem
1995 Buick Regal 6 cyl Front Wheel Drive Automatic ??? miles
all my gears are out except for first gear and its making a clattering sound.this happened while i was driving down the road.no warning. just stopped working. why is it doing this?
Dec 17, 2009 at 10:31 AM
ERNEST CLARK
  • 1,730 POSTS
there are several reasons why you transmission won't shift out of 1st.
1) The clutch plates have burned up
2) Some of the rubber seals inside of the valve body are
leaking and not allowing the fluid to circulate correctly.
3) Dirt or dibre has clogged some of the passages inside
of the valve body
4) Your power control module is failing. (least likely)
Your only recourse is to have the transmission tested by a professional.
Dec 30, 2009 at 12:52 PM
