1995 Buick Regal Power Drain
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOYCE R.
I've changed the alternator and battery. Checked every fuse I could find, but there is a power drain somewhere. I took the battery out of the car overnight and tested it in the morning and the it was fine. If I leave it in the car overnight in the morning it is dead. Anyone have an idea.
Jul 17, 2008 at 8:00 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5aeee626eb="Joyce R."]Electrical problem
1995 Buick Regal 6 cyl Two Wheel Drive Automatic 104000 miles
I've changed the alternator and battery. Checked every fuse I could find, but there is a power drain somewhere. I took the battery out of the car overnight and tested it in the morning and the it was fine. If I leave it in the car overnight in the morning it is dead. Anyone have an idea.[/quote:5aeee626eb]
Ok, to narrow down the circuit the drain is on you can do this....
Using a test light - Disconnect the positive terminal connect the test light between the Positive Cable you just took off and the Positive Post. The test light will light up since you have a draw. Goto your fuse block and pull the fuses 1 at a time checking the light each time. Once the light goes out that will be the circuit the draw is on.
Post findings here in forum.....
Jul 17, 2008 at 11:11 AM
