1995 Buick Regal Low Coolant Light
1995 BUICK REGAL
60,000 MILES • 6 CYL • FWD • AUTOMATIC
LYNWOOD CLARK
The low coolant light comes on intermittently. No seeming relationship to outside air temperature, length of time the engine has run, etc. Temperature stays within limits and does not move significantly when the light comes on or goes out. I've topped off the antifreeze level with no apparent effect. What is the most likely cause of the light coming on?
Sep 12, 2010 at 11:22 AM
  • 110,244 POSTS
There is a coolant level switch in the overflow. It may be going bad.
Sep 14, 2010 at 3:48 AM
