1995 Buick Regal idealing issues
180,000 MILES • 6 CYL • FWD • AUTOMATIC
MR_JVILLE
i can start the car so i know i got pressure.. put when i do get it started it seems to run fine as long as im giving it gas.. once i lay of the gas it stalls out... i have replaced the fuel filter which was pretty much clogged... and my fuel pump is turning on everytime.. what is my next step to figuring this damn car out??
Sep 8, 2009 at 6:06 AM
  • 75,988 POSTS
Try cleaning out the idle air control valve and see what happens.
Sep 8, 2009 at 7:04 AM
MR_JVILLE
i have checked the ideal air control valve and checked out the fuel injectors... do you think im doin all this work for nothing and my fuel pump is just dying on me??? because now its soundin pretty rough when it is running and when i give it gas it seems like its starving for it....
Sep 8, 2009 at 8:19 AM
  • 75,988 POSTS
Check the fuel pressure to rule out a weak fuel pump and defective fuel pressure regulator to include testing the TPS and MAP sensors.
Sep 8, 2009 at 1:33 PM
