1995 Buick Regal fuel line
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOEMAUI
my fuel line seems to be clogged from the filter to the tank.is it ok to blow this line out?
May 4, 2010 at 5:08 AM
  • 110,251 POSTS
Are you sure it's plugged and the problem isn't a bad fuel pump? As far as blowing out, I believe it will damage the fuel pump if it is still good.
May 5, 2010 at 12:49 AM
