1995 Buick Regal Engine stalls
DBOY510
  • 1995 BUICK REGAL
  • 6 CYL
  • FWD
  • 175,000 MILES
I have a 95 regal that idles rough and stalls when the car warms up. Before it stalls it makes a backfiring sound, it shakes, then it stalls. After it stalls the car wont start for hours. Can anyone help me out?
Sunday, December 27th, 2009 AT 2:50 AM
When it stalls don't wait for hours do below immediately to catch it if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
_________________
Sunday, December 27th, 2009 AT 3:05 AM
