1995 Buick Regal breaklights
94,599 MILES • 6 CYL • 2WD • MANUAL
ANDREBHALL
My taillights and break lights went out. How do I fix it
Apr 2, 2010 at 4:14 AM
TWOSTEPPER
  • 42 POSTS
I'd start by checking applicable fuses and bulbs. Tail-lamps get voltage from the headlamp switch. Your lower brake lites and turn signal at the rear, use the same bulb filament, just not at the same time. Dual filament bulbs, one filament for tail, the other for stop/turn. I'd check for voltage and ground at the lite wiring.
Apr 2, 2010 at 6:17 AM
