My Buick Regal brake lights don't work. My tail lights and my turn singnals work. I changed the bulb and the fuses. What do I look @ know?
Aug 21, 2009 at 7:06 AM
✓Experienced Mechanic
Check and test the brake switch -disconnect the switch and jumper the connector did the brake light come on. Also do you have a high mounted center brake light is it coming on too?
