1995 Buick Regal brake wiring
FRIESMMM
Brakes problem
1995 Buick Regal 6 cyl Two Wheel Drive Automatic
Have a 95 Buick regal 3.8. I have brakes on the left side and third but not the right. there is 3 wires that come out of the light bulb socket green, brown, and black. No power on any. Can I splice into the power on the left side or what can I do?
Nov 29, 2009 at 4:04 AM
JDL
  • 16,098 POSTS
Welcome, does the right turn signal at the rear, work? The lower brake lites and turn use the same bulb filament, just not at the same time. The dark green wire carries voltage for that circuit. Right now, my guess is a faulty turn signal switch? There may be a multiwire connector under the dash, close to steering coulmn. You might be able to test dark green wire at that connector. If voltage there and not at the rear, problem with wiring circuit. If no voltage at connector, with brake applied, either the wiring in the steering column or turn switch. All repair info, says to disarm the air-bag, where applicable, when working aroung the column.
Nov 29, 2009 at 4:21 AM
FRIESMMM
yes the turn signal works on that side..
Nov 29, 2009 at 10:00 AM
