1995 Buick Regal brake lights
DNDWN352
Electrical problem
1995 Buick Regal 6 cyl Two Wheel Drive Automatic
i have replaced the brake light switch under the dash,all bulbs are good and fuse is good but the brake lights still do not work. what else could i check?
Apr 26, 2009 at 6:17 AM
DOCFIXIT
  • 18,828 POSTS
The brake light circuit goes through the turn signal switch and the multifunction switch most likely will need replacement.
Apr 26, 2009 at 6:32 AM
