1994 Buick Regal Starting Problems
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
MANTIS1259
The car doesn't start 20% of the time. If it doesn't start on the first try it won't start again unless I wait about 15 minutes. I have never had the problem when the gas tank is full. The car runs fine once it is started.
Apr 21, 2008 at 12:22 AM
2CARPRO JACK
  • 11,533 POSTS
So it turns over but wont start sometimes. Have a fuel pressure test done on it. Some of those older GM's had a "pulse dampener" on the fuel pump that when bad will by-pass pressure, unless the pump is completey submerged in fuel. If fuel pressure is the problem, the new pump should have a piece of injection hose to take the dampeners place.
Apr 21, 2008 at 12:35 AM
