1994 Buick Regal GAS TANK REMOVAL
BEXILUS2000
1994 Buick Regal 6 cyl Front Wheel Drive Automatic
I'M TRYING TO TAKE OFF MOUNT STRAPS OF GAS TANK BUT BOLTS ARE CONNECTED TO A FASTENER WHAT TOOLS DO I NEED TO TAKE OFF GAS TANK
May 26, 2008 at 11:14 AM
BLACKOP555
  • 10,386 POSTS
i usually buy replacement straps and cut the old ones off with bolt cutters.
May 26, 2008 at 2:01 PM
BEXILUS2000
ABOUT 94 BUICK REGAL FUEL TANK REMOVAL
Jun 6, 2008 at 9:43 AM
BEXILUS2000
I HAVE REPLACEMENT STRAPS BUT IM WORKING WITH VERY LITTLE SPACE FOR BOLT CUTTERS. BOLTS ARE SECURE BY METAL TYPE CLIPS AND TURN WHEN I TRY TO REMOVE WITH RATCHET
Jun 6, 2008 at 9:53 AM
BLACKOP555
  • 10,386 POSTS
can you get vice grips up in there so the nut doesnt turn? if youc an verify its just the nut turning you could tack weld a little bit so the nut doesnt turn.
Jun 7, 2008 at 5:45 AM
