Electrical problem
1994 Buick Regal 6 cyl Front Wheel Drive Automatic
Replaced ABS/Master Cylinder unit, Powermaster III and the brake lghts are on constantly even when key is removed. Only way to run them off is to remove the fuse. Have checked power voltage and always HOT. Also Check Engine and ABS gauges are always on. Does anyone have any ideas on how this could be happening?
Oct 22, 2008 at 4:41 AM
