Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Regal
Engine
Symptoms
Not Running
1994 Buick Regal
1994 BUICK REGAL
59,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIGDOG7897
MEMBER
1 POST
car will not start unless you push gas pedal to the floor and release then you start the car. will not start if you just turn the key
Jul 10, 2010 at 12:07 PM
Experienced Mechanic
Check the fuel pressure-if ok,check the coolant temperature sensor and test the throttle position sensor and clean the idle air control valve.
Jul 10, 2010 at 3:30 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
