1994 Buick Regal
DANASORENSEN
1994 Buick Regal 6 cyl Two Wheel Drive Automatic
I can turn it over but it wont stay running for more then 5 seconds. Do you know what is going on?
Oct 1, 2010 at 9:40 AM
WRENCHTECH
  • 20,758 POSTS
The first thing to check would be fuel pressure. Use a gauge. There is a service port on the fuel rail.
The spec isIgnition ON Engine OFF 40.5 to 47.0 psi
With Regulator Vacuum Applied [1] 3.0 - 10.0 psi Less than Ignition ON Engine OFF
Oct 1, 2010 at 10:26 AM
