1994 Buick Regal
KENDOGG2008
1994 Buick Regal
I am having problems with my brake lights. All the fuses are good, the bulbs are all brand new, the brake switch has been replaced and the wire connectors have been stripped and rewired. When the parking lights are on the rear lights come on and the turn signals also come on. The wires are hot because when the test light is touched to the hot wire the light comes on. Is there another place that I can look to correct this issue or try something different to get these dang lights to come on?
Oct 18, 2008 at 12:39 PM
MITCHKOZ
I had same problem which turned out to be common on this make and model. The brake lights run through the turn signal switch. Jiggle it around while pressing on the brakes, and have someone watch the brake lights. Pulling forward on the stalk like turning on bright lights is was fixed it for me, the brake lights started working. Good luck.
Oct 19, 2008 at 10:07 AM
