I am trying to replace the transmission control solenoid, can you tell me or show me a picture where it is located? Thank you.
Sep 22, 2009 at 8:15 AM
✓Experienced Mechanic
The TCC solenoid and the other solenoids are in the transmission valve body, you need to drop the tranny pan to get at it-
Sep 22, 2009 at 8:22 AM
JDLONGANECKER
MEMBER
[quote:98093955c9="rasmataz"]The TCC solenoid and the other solenoids are in the transmission valve body, you need to drop the tranny pan to get at it-[/quote:98093955c9]
I've done that, however, I didn't see where inside the solenoid is located.
Sep 22, 2009 at 12:05 PM
The solenoids have wires on it and are contain within the valve body
Sep 22, 2009 at 12:10 PM
JDLONGANECKER
MEMBER
[quote:13e1e4c009="rasmataz"]The solenoids have wires on it and are contain within the valve body[/quote:13e1e4c009]
How far up is the valve body and which side is it on. As you might be able to tell, I've never done anything like this before. If you have pictures, that would help. Thxs.
Sep 22, 2009 at 12:17 PM
The tranny control solenoid looks like this-its within the valve body-its right on top of the tranny pan once the pan is removed.
