1993 Buick Regal not blowing
200,000 MILES • 6 CYL • FWD • AUTOMATIC
NBELL
Im not sure what to do because i've never ran into this problem before. The heater is not blowing any air, or air conditioner. I checked the fuses and relays. Could it be the blower? please help
thanks guys
Jan 7, 2008 at 6:42 AM
  • 75,988 POSTS
Could be the blower motor itself-try direct power to it and see what happens if it comes on-find the blower motor resistor and test it.Could also be the control switch.
Jan 7, 2008 at 6:51 AM
INDO
Check out the following link. I have to wonder if you're having a similar problem and if it could be the ignition switch.
https://www.2carpros.com/forum/2000-regal-cruise-amp-fan-system-stop-working-same-time-vt65647.html
http://www.buickforum.com/forum_posts.asp?TID=1299&PN=1&TPN=1
Jan 18, 2008 at 9:43 AM
