I recently had a leak in my tranmission that was fixed (on the 2nd visit) with the installation of an external cooler. I then had to take the car back for the 3rd time as I once again had problems accelerating. The shop told me the vent had possibly sucked in some air and that the air bubble had now "burped". They filled the system and could find no leaks. I also had some work done on the engine right after this (the same day - replaced pcv valve and the throttle position sensor). Now, the car lurches when I put it into gear. The only time it does not lurch is when I put it into park. I notice some hesitation when it is shifting gears while driving as well. I need some guidance on what may really be going on.
Jun 8, 2008 at 5:29 AM
