1993 Buick Regal hesitates and stalls
BARNESA
Engine Performance problem
1993 Buick Regal 6 cyl Front Wheel Drive Automatic 240k miles
This car has done this for some time. Its a 3.1.engine. Only certain times it will hesitate or try to quit running very quickly, more so accellerating up a hill at any speed, and sometimes will be fine. I have replaced-- tps, iac, ign. control module, coils, plugs/wires,pvc. I know its with ign.because using timing light there is a pause in light when miss occurs. Also there is no diag. code set. Thanks for your help.
Feb 5, 2009 at 1:24 PM
MASTERTECHTIM
  • 4,750 POSTS
chec crank sesor ande wiring connector to the crank sensor. sometimes the terminals get widened and will intermittently make a bad contact
Feb 6, 2009 at 6:02 AM
