Engine turns over but won't start
PHATCATS
Engine Mechanical problem 6 cyl Front Wheel Drive Automatic
The engine turns over but won't start. I'm not getting fire. Any suggestions would be very appreciated. The only manual I have access to is for a Buick Skylark.
Thanks,
Kevin
Mar 19, 2009 at 7:37 AM
  • 55,658 POSTS
This sounds like a problem with the crankshaft angle sensor not getting a signal to the ECM. Here is a guide that will show you what you are in for when doing the job.
This guide can help as well
You will need to remove the balancer to replace the sensor
https://www.2carpros.com/articles/how-a-harmonic-balancer-works
Here is how to change the sensor on your car
Check out the diagrams (Below)
Cheers, Ken
Dec 2, 2017 at 10:30 AM
