i want to know why my engine keeps stalling and I want to know why, Also it keeps smelling and it may be leaking oil but I'm not really sure. I need some help.
Tuesday, December 16th, 2008 AT 9:48 AM
MECHANIC
It can be anything problem areas could be tune-up, fuel pressure and igniton timing, PCV and EGR valves, clogged exhaust system, Idle air control valve/throttle position sensor and the list goes on. Check the above and comeback with results we move from here.
